Oscilloscope Amplitude Scaling Problem
I am currently using an Agilent 4 Channel Oscilloscope to to take in data from a system I created. The Waveform I am trying to create is a simple Sine Wave on all 4 channels. On the Oscilloscope itself, the amplitudes are correct, but when I put them in the Labview program, they come out in the 100s. How can I fix this issue so that it displays the correct data, around 10. I have tried using the scaling in the Instrument  Assistant VI, but after every time I run it the scaling disappears and I have to redo it.
Thanks in advance
(2,669 Views)
Just like your post here, you have not provided essential information. Why is it so difficult to provide the model number? Why don't you attach the code? Did you even try to find an existing driver instead of using the Instrument I/O Assistant?
(2,657 Views)
