Oscilloscope VI's
So I have been trying to create, or find a pre existing VI, of an Oscilloscope that allows me to wire in the voltages that it reads, like from a DAQ card. So far I haven't had much luck. Any ideas?
Message 1 of 9
(7,217 Views)
I have an idea.  How about telling us what kind of scope it is?  (Make/model)  😉
Bill
CLD
(Mid-Level minion.)
Message 2 of 9
(7,216 Views)
I don't have a Oscilloscope, I'm trying to make one on LabView or find one that lets you wire in your own voltages from a DAQ card.
Message 3 of 9
(7,210 Views)
Sorry - I thought you were trying to make a real Oscope work with LabVIEW!  Wat have you tried so far?  It seems all you need is a chart to display your data?
Bill
CLD
(Mid-Level minion.)
Message 4 of 9
(7,201 Views)
Essentially yes, all I really need is a waveform graph that displays my data. I have this but the problem is that it isn't triggered so my data flows through the screen, its not stable in one place like an oscilloscope. Its very simple but it works.
Message 5 of 9
(7,195 Views)
AH, you want a "Waveform Chart" with the "Chart History Length" set to the number of samples you want and an update mode set to "Scope Chart"
(Then read smaller chunks at a time so the chart actually updates at a pleasing rate for the user)
Message 6 of 9
(7,188 Views)
Thanks!, that seems to be closer to what I want, but how would you trigger it to just read on section of the data so the data isn't constantly moving across the chart?
Message 7 of 9
(7,179 Views)
Message 8 of 9
(7,129 Views)
You must not be very familiar with a scope if you don't understand the nature of a trigger and why the display is 'stable'. A DAQ card can be set for continuous acquisition and your 'stable' display may be meaningless in any case.
Message 9 of 9
(7,120 Views)
