Out-dated example - picture to pixmap
There used to be an example of how to efficiently convert a picture to a flattened array for saving as a BMP/JPEG/PNG. That example http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/862567530005f09e8625682e003ac6d9?OpenDocument used a CIN that appears to no longer be available in LabVIEW 6.1.
Does anyone have an update to this example?
Pete
(2,770 Views)
CIPCE;
Now, all you have to do is to create an invoke node of the picture indicator/control and select the Get Image method. Make sure you resize the picture indicator to the size of your image in order to get it all (Create a property node and set the Draw Area Size.)
I have a copy of the vi you say that use a CIN. In case you still need that vi, let me know and I can e-mail it to you.
Regards;
Enrique
www.vartortech.com
(2,770 Views)
