Out of memory error
I am running a large application using TestStand and LabVIEW. Occaisionally I am encountering an Out of Memory error. This error occurs on a test step where I am loading a large file into memory where I analyze it for transitions. I know the problem is happening during the open file portion of the vi. We have more than enough memory, however, I suspect that after running many tests throughout the day (without exiting labview/teststand) eventually the system boggs down. Is there anyway to clear memory? If there was something I could do after each job, I know the performance would be better.
(3,018 Views)
Hello Lori,
You can force an "Unload all Modules" to occur inside your sequence by using an ActiveX Action step configured as follows:
Reference: RunState.Engine
Automation Server: NI TestStand API x.x (Ver 1.0)
Object Class: Engine (IEngine)
Create Object checkbox: OFF
Call Method or Access Property checkbox: ON
Action: Call Method
Method: UnloadAllModules
Attached is a TestStand 2.0.1 sequence file that demonstrates this, and it works in TestStand 3.x as well.
David Mc.
NI Applications Engineer
(3,018 Views)
