OutPort.vi from Windows XP
Dear friends,
how to use OutPort.vi and InPort.vi from Windows XP in order to manage
COM-port pins?
Al
(3,741 Views)
Hallo, Al,
Du (mseminovREMOVE) meintest am 02.01.02:
> manage COM-port pins?
Might be you need "hwaccess.*" or "accesshw.*" from the NI server.
Greetings!
Helmut
Please excuse my gerlish!
(3,741 Views)
I have two suggestions that I haven't tried but should work:
1. You can set the compatibility mode for you're LabVIEW application to
Windows 98/Me. Do this by right clicking on you're LabVIEW shortcut and
select properties. Click on the Compatibility tab. Turn "Run this program
in compatibility mode for:" on and set it to Windows 98/ Windows Me. The
next time you load LabVIEW you should be able to use the Port I/O vis
without getting an error.
2. Download the Port IO VIs for NT and Windows 2000. You should be able to
find the somewhere at www.ni.com.
Best Regards,
Neal Pederson, President, VI Control Systems
1923 Mendius Lane, Los Alamos, NM 87544
TEL: (505) 662-1461, FAX: (866) 422-2931
np@vicontrols.com, www.vicontrols.com
"Al I Sem"
wrote in message
news:a0v6o2$n17$1@babylon.agtel.net...
> Dear friends,
> COM-port pins?
> Al
(3,741 Views)
> Best Regards,
Hi Neal,
which LabVIEW shortcut do you mean?
I have error messaages in ser
ial vis too, so maybe your info helps me to.
Thx,
Rainer
(3,741 Views)
Visite the link
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DEBD56A4E034080020E74861&p_node=DZ52058&p_submitted=&p_rank=&p_answer=&p_source=External
And download accessHZ.zip an install.
Good luck
Sorry for my english
(3,741 Views)
