Output Constant Voltage through DAQ
Hi!
I was wondering if this code would work to output a voltage if the stop button was pressed. Is it setup correctly? Do I need the wire between from the case selector to the data entry on the DAQ Assistant?
Thank you!
(3,460 Views)
Accepted by topic author mkapler1
Is that a digital output or an analog output?  If digital, then the True would cause the digital output line to go high.  If it is an analog output, then you need to wire a voltage value to the Data input.
When do you turn the voltage back to zero?
(3,438 Views)
