Output Constant Voltage using myDAQ
Hi , im stuck on this few days , i will appreaciate , if you can explain , how to implement this : how to set value when the vi starts to run, and change it to 0 when the VI ends.
Message 11 of 14
(1,867 Views)
Go to the DAQmx palette. Click DAQ Assistant and drop it on the block diagram. Either a pop up will show right away or you double click it to configure it. Set it up as a *Generated* signal, instead of like your current acquiring assistant, and follow through the settings to match your device. Rinse and repeat for the end case to set it back.
Happy Independence Day!
Cheers
Message 12 of 14
(1,845 Views)
"Rinse and repeat for the end case to set it back."
im sorry but i didnt understand it
Happy independence day
Message 13 of 14
(1,837 Views)
Repeat for the end case to set the value back to zero.
Cheers
Message 14 of 14
(1,820 Views)
