Output Value Not Updating
My phase difference (phi) value is not being updated if I change my input phase values. Everything else is being updated while the looping is running. I have to stop and re-run the vi just to update phi value.
Can someone please help.
(3,556 Views)
Accepted by topic author eddyrockz
The signal generators only look use the Phase input on reset.  So if you want the phase to be able to change, you have to reset the signal generators.
(3,514 Views)
Thank you so much. How silly of me lol to not be able to spot this.
I set reset signal = 'True' and now all the values update perfectly.
Thank you for your help.
(3,484 Views)
