Output a sine wave to a PC speaker
I am trying to generate a sine wave and output it to a PC speaker. It works ok, but I can hear breaks in the sound, perhaps at the end of the sample size. Is there a way to avoid such an issue. Attached is the VI.
Thanks.
(4,297 Views)
The problem is that you are using an express VI that load a sound, starts generation and at the end stops generation - each time its called. There is also some processing of the data that the express VI redoes each time it's called.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,274 Views)
Sorry I can't open your vi since I am using LV2011.  Did you try the generate sound example: Generate Sound.vi  This plays (at least what sounds like to me) a smooth sinewave on my computer.
C:\Program Files (x86)\National Instruments\LabVIEW 2011\examples\sound2\sound2.llb\Generate Sound.vi
-SS
(4,256 Views)
Accepted by topic author SysB1
Thanks. I came across this one and used it. It works, but I wasn't sure why the other one didn't work.
(4,235 Views)
