Output a voltage from DAQ LabVIEW
HI all,
Say I had a thermocouple (which isnt overly relevant in this case) that was being read by a DAQ and giving me a temperature every minute (essentially I just have a new number every minute). I was wondering if it was possible to make a LabVIEW VI that would take a number it is given and if this number if above a certain value, output an analogue voltage (doesnt matter if it is the max 10V that the DAQ  9207 i'm using can handle) from a terminal on the DAQ. I have already used several applications taking readings through a DAQ (taking inputs and reading them through DAQ assistant), although I have never tried to output anything through a terminal on the DAQ previously. I was wondering if this is possible, and if so how I could do it. Any example VI's of outputting a voltage through the DAQ given a condition is fulfilled would be excellent and greatly appreciated.
Many thanks in advance!
(3,482 Views)
Yes - it is absolutely possible.
Have you tried looking at some of the DAQmx examples in the example finder - there will be examples that show how to output on the DAQ (essentially using a DAQmx write node with a value - it's very similar to a read). You will end up with two separate tasks - one for the input and one for the output.
Some simple logic (greater / less) will allow you to compare your read value and 'select' (hint hint) the value to write to the DAQ.
Look at the examples, have a go and if you get stuck then post your attempt here and we'll try to help you find out what's wrong.
(blog)
(3,471 Views)
