Output data from subVI to main program
I am trying to output data from subVI to the main program in real time. But I found the the value can be only trasferred when the subVI is finished.
I make some research and I think using queue is the best, but global variable.Can you any give me some tip on using queue to transfer data from subVI to the main program in real time?
Thank you!
(4,309 Views)
Look at the Simple Queue.vi example that is installed with LabVIEW.  If Loop 1 were in a subVI it would generate data that the main VI could consume in a parallel loop (either in another subVI or on the main VI block diagram).  And yes, a queue is the way to do it if you want to make sure all the data gets transferred, and in order.  If all you care about is the current value (and are ok with lossy communication), then look at using a notifier.
(4,286 Views)
You might also want to checkout the two producer/consumer design patterns. One uses queues and the other event. They might give you some ideas also.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,275 Views)
This thread is a duplicate - http://forums.ni.com/t5/LabVIEW/Output-data-from-subVI-to-main-program/m-p/2529222 where a reference is used.
(4,269 Views)
Yes,sorry I cliked the post twice.
(4,247 Views)
