Output data type of Read from XML file.vi
LV 7.1:
How can I enforce the output data type of the polymorphic "Read from XML file.vi" to be a string instead of an array of strings?
(2,679 Views)
In the Examples, there is a Read Data from XML file.vi, that shows how to do this.  You basically have to index the array and re-concatenate, or separate, depending on how you want to display.
eric
(2,669 Views)
@alkazaa wrote:
LV 7.1:
In reply to my own post:
I found the answer and described it in another forum
(2,654 Views)
