Output message in command prompt
I would like to run my LabVIEW EXE in command prompt.  After the execution of the EXE is done, I want it to output some speciific message in command prompt.  How do I do that?
Kudos and Accepted as Solution are welcome!
(4,314 Views)
What exactly is it that you are trying to accomplish?
You can certainly call a LabVIEW-built executable from a command line, but the executable can not natively return something when it finishes.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,269 Views)
Try this VI, build an exe, and run it. The application will open another command window however. I could not figure out a way yet how to output values to the very same command prompt...
or maybe here you find a trick:
http://forums.ni.com/t5/LabVIEW/How-to-send-a-command-to-an-already-open-command-window/td-p/2101410
(4,248 Views)
Can you write a batch file to run LabVIEW, and display a message when LabVIEW exits ?
This way you can display the message in the same DOS window.
George Zou
(4,212 Views)
