Outputting Guide Lines on Waveform Graph
I have a graph of temperature vs. time, the temperature (y-value) should be between 75 and 85 degrees and I would like to display a red line on the graph to show where 75 and 85 are to easily declare if the temperature is within the limits. I want it to display on the front panel as well as in the excel file I'm exporting to.
(1,759 Views)
Hi Sam,
Use two more plots in the graph. (Or use cursors.)
For the data saving you just need to save two more values per row…
(1,754 Views)
