Outputting external scan clock rate??
I'm externally controlling my scan clock rate with a rotary shaft encoder that gives 720 TTL pulses every revolution. I've used the AI Clock  Config vi to set this up. I'd like to know how i can monitor, on screen, the actual rate at which I'm scanning. Essentially this would be a measure of my encoder rpm. How do I do this?
Theo
Message 1 of 1
(2,549 Views)
