Outputting to command window from C++ DLL in LabWindows/CVI
Hello all,
I am new to Labwindows programming. I call a C++ DLL from Labwindows/CVI,
which works just fine.
I would like that, from within the DLL which I am making with MS Visual C++
6.0, some lines of text would be put on the screen (i.e., the command window
of CVI/Labwindows).
When I just use a PRINTF or COUT << command in the C++ code the text does
not appear.
I suppose I have to give a handle to the command window to the DLL or
something..
Can anyone tell me how to go about doing this???
Thank you all,
Gunter
(2,996 Views)
perhaps command window is a bit off, what I mean is the Standard IO window
in CVI.
"GV" wrote in message
news:atkd14$bpd$1@snic.vub.ac.be...
> Hello all,
C++
window
> of CVI/Labwindows).
> not appear.
> something..
> Thank you all,
> Gunter
(2,996 Views)
You've posted your qestion to the LabVIEW forum. LaabWindows has it's own here.
(2,996 Views)
