Ouvrir un projet LabVIEW 2010 avec 2011
Could you just try to create a new project in LV2011 and insert yours VIs inside?
If you have LV2010 installed yet, your projects works now??
Nicolas M.
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter avec LabVIEW - Développer avec LabVIEW
Message 11 of 16
(769 Views)
An other thing I had not precised : the classes (and so the VIs) are all encapsulated in a classic library (.lvlib) which is then used by the project to build the packet library.
So what do you think about, in a first time, creating a new library with labview 2011 and inserting the VIs inside ?
Message 12 of 16
(768 Views)
I just try to delete the library and then open a class (I clicked Ignore Item when it was searching library) and LV doesn't crash. So maybe the problem seems to come from this library...
Message 13 of 16
(766 Views)
Yes it's possible.
Try to rebuild the library.
If it doesn't works, it is necessary to use a library? Try to insert VI per VI on your project.
Nicolas M.
Message 14 of 16
(764 Views)
Ok finally I think the problem doesn't come from the library itself.
I copied the VIs in an other folder (all dependances of class, library...weren't found and I ignored them). All the VIs opened correctly except 2 for which I had the habitual crash.
When I was opening class, library or project before, LV was trying to recompile all the VIs and it crashed when it arrived to one of these 2 cases. (Say me if I'm wrong)
I will open them with LV 2010 to investigate on code.
Message 15 of 16
(762 Views)
I found the problem ! (but I don't explain it...)
It was coming from only one VI (the second was calling the first).
The problem comes from a property node. When I delete it I can open the VI with 2011 (and replace it).
Concerned part of the code :
Message 16 of 16
(758 Views)
