Over Range on USB-6008?
Dear Board,
I am wondering if an AC signal operating at the limit of the selected range on the 6008 will over range it? Is the  range limit a dc value; or is there over range capabliliy built in for AC RMS measurements? The manual isn't clear on this. Has anyone delt with this?
Thanks a lot!
Mike
(2,737 Views)
Accepted by topic author Cburg
Mike,
the 6008 does not have a special method of input coupling. Therefore, the given maximum range is a DC value.
So if you select 5V as maximum range and have a sine wave with Vp = 2V and an offset of 4V, you will cut off the positiv wave at 5V.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,728 Views)
