Overlapping frames in FFTS
I was wondering what the most efficient and neatest way of overlapping
frames when doing an FFT in labview and if there were any examples.
regards
Tom
(4,150 Views)
Tom,
To perform overlapping FFT in LabVIEW you'll have to extract the different overlapping time segments your self. There are 2 different options, either extracting the time segments one by one from your overall signal, or by passing the needed overlap section using a shift register inside an additional for-next loop.
If your overall signal is not too big, I'll recommend you to use the first technique, but if your signal is very long or runs continuously, you'll have to use the second technique.
The attached example shows how overlap FFT works on a relative short transient. The VI is explained on the front panel. (LabVIEW 6i or higher required)
Alain
(4,150 Views)
Hi:
Read your program, I found that the Averaged power FFT output of the For loop is the last value, it is determined that the entire data is the average FFT do?
Best Regards
(3,606 Views)
