P E Micro Cyclone Pro
For some reason I am having the darndest time loading cyclone_Pro_stdcall.dll with LabVIEW 6.1.  I know there's got to be some trick to getting the library function calls to work properly.  At this time I do not get the device to connect through the DLL but I have managed to use the supplied applications to talk to the device.
Any advice?
(5,482 Views)
Hi Jeff,
Could you supply some more information about how you are calling the dll. Are you using the call library function or a cin? What kind of datatypes are you trying to pass to and from the dll. Its a possibility that you may have to change the type binding. Are you getting any kind of errors or is the dll just not working?
Andrew Eddleman
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(5,458 Views)
Hi Jeff,
I would like to automate the programing process of our production line.
We use the PEmicro Cyclone Pro.
Did you wrote a driver for it? I apreciate if you could share it or some tip about how you did it.
Regards
Marcio
(4,693 Views)
As I recall (And that was 4 years ago)
I wound up using the DLL through a few Call library function nodes.
There was a need to dynamically load and unload the TestStand modules that called the dll calls.  but that probably has changed for modern OS Teststand and LabVIEW versions.
(4,689 Views)
