PAR 273 - Schematics?
Good morning,
I'm trying to connect a PAR 273 potentiostat to LabView using a GPIB-USB cable from NI, however I have always this error on the potentiostat I/0 Err 2 and I/0 Err 4.
I have also some problem with the PAR273 alimentation and inside card I think.
Since i have no manual, I wonder if some of you have a detailled schematics of what is inside the PAR 273 (especially a detailled schematics of the alimentation). I know that theses schematics are in the manual...
Thanks a lot for your help
(3,639 Views)
Greetings Kevin,
Since the PAR 273 is not a National Instruments product, it is not likely that you will find the manual here. The website from Princeton Applied Research is probably a better place to start.
However, the GPIB-USB is a National Instruments product and we want to make you successful with this device. Browsing through our website, I found This Article in our LabVIEW Community. It's an example code that was posted by someone who successfully used this code to control a PAR273A through GPIB-USB.
Please take a look and keep us upto date about your progress.
Kind Regards,
Wouter
Applications Engineering
National Instruments Belgium
(3,610 Views)
