PAR 273 potentiostat
Greetings,
I am trying to use a PAR 273 potentiostat to perform and record cyclic voltammetry via GPIB/USB interface with a computer. Using labview's I/O feature I can control the potentiostat with the commands provided in the manual. I have determined how to run a CV, but I can not figure out how to have the device record the data. Can anybody with experience in using PAR potentiostats advise me as to how to save data points? I read in the manual that the potentiostat can save data to a curve in its internal memory and then dump the data to the computer, but I have not been able to save the CV data to the curve. Thank you!
(2,938 Views)
Hey alexouofa,
It's probably best to contact PAR about saving the data on the device if you haven't already. We can definitely give you information about how to process the data once you get it on your computer, but you will probably not get the best information about the specifics of the 273 on this forum.
Cheers,
Ryan
(2,881 Views)
