PC Crash with Labview 7 and windows 2000
Problem:
the PC does reboot without any prompt when a LV 7 vi is running; the reboot seems to occur randomly (no time dependent); sometimes instead of rebooting, the PC switches to the blue screen with the following message:
Stop: 0x0000001E (0xC0000002, 0x80419292, 0x00000000, 0x00000000)
KMODE_EXCEPTION_NOT_HANDLED
Xxx Address 80419292 base at 80400000, date stamp 3EE6C002-ntoskrnl.exe
Starting memory download
Configuration:
Intel Pentium IV - 2.66 GHz - RAM 1 Gbyte - Video chipset Intel 82865G;
OS: Windows 2000
DAQ Board: PCI MIO 16 E1;
Labview 7 express - NIDAQ 7.1
Note:
The VI that causes the reboot uses the DAQMX to generate an Analog Output with analog trigger.
(3,005 Views)
You probably want to post this problem to the DAQ message board as well
since LV itself really can't cause either of these problems on a
protected OS. Be sure to be very explicit about what HW boards and what
DaqMX calls you are making along with which version of the driver you have.
Greg McKaskle
(3,005 Views)
Thanks a lot for the suggestions. I just posted the problem to the DAQ message board...
(3,005 Views)
