PC Fan RPM Measurement and PWM Control
You had mentioned 1e6 RPM in your original message, so that would obviously be an erroneous reading.
So eliminate any values that are too large, to start with.
Then following that with your averaging and percentage change seems like a way to take care of the false, but otherwise plausible readings.
Message 11 of 12
(1,259 Views)
Hi.
I need to see the VI in labview 2015. It dosent open in my labview version since you have been using labview 2017. Can you send me similar VI which I can use in 2015?
Thanks for your help
Message 12 of 12
(910 Views)
