Showing results forĀ
Search instead forĀ
Did you mean:Ā
PC Recommendation
I am looking for recommendation for  a decent and good priced  PC that we will use for development. We are using labVIEW 2017 and 2018.
Message 1 of 8
(8,370 Views)
System Requirements for LabVIEW Development Systems and Modules
=== Engineer Ambiguously ===
Message 2 of 8
(8,339 Views)
Accepted by topic author avega
I think you can do a bit better than a Pentium 4 and 1GB of RAM these days šŸ˜‰
If you get a decent processor, 8GB of RAM, and a 1080p screen you should be good for most things. If you want to hook up hardware, make sure you get something with a bunch of ports.
Message 3 of 8
(8,333 Views)
@avega wrote:
I am looking for recommendation for  a decent and good priced  PC that we will use for development. We are using LabVIEW 2017 and 2018.
For test systems, I have often gone with Super Logics.  I would also recommend Stealth (apparently now part of Sparton RE).
Message 4 of 8
(8,278 Views)
Hello
If you are going to use multiple versions of labview, go for atleast 8 GB of RAM, i3/i5 latest gen. processor and a 1080p monitor for sure and it also depends on the number of toolkits you are going to use.
-Rahul
Hit KUDOS for Thanks
Message 5 of 8
(8,272 Views)
Honestly you don't need anything special for LabVIEW development.
Any of today's typical desktop systems will be fine.
My current development PC is a Dell (My company only buys Dell) i5 16GB RAM on-board Intel graphics and it's just fine.
Up until about three months ago I was using an older i5 with 8GB RAM and I really see no difference beyond the loading time is faster on my new computer because it has a SSD.
Message 6 of 8
(8,237 Views)
Thank you.
Message 7 of 8
(8,138 Views)
The thing about getting lots of ports in your accepted solution is a mute point.
I find it better to buy "off the shelf" computers for our ATE systems and use USB based GPIB, serial, MODBUS, Etc. interfaces.
This way if a computer dies for whatever reason I can replace it with any "standard issue" PC my company is buying.
Returning  the ATE system to service much faster than having to special order some non-standard build and wait for it.
Message 8 of 8
(8,127 Views)
