PC-TIO-10 base address error
I've verified several times that the jumpers are set correctly on the board
for 0x1A0 (the default base address setting for this board). Also, I've
checked in Measurement & Automation and it is set to use 0x1A0 to 0x1A7.
There are no conflicts. However, I am still receiving a 'The device is
not responding to selected base error message.' (I've also tried other addresses
within 0x100 and 0x3FF) Someone have this sort of problem?
(3,008 Views)
In article <38be8e53@newsgroups.ni.com>,
>addresses
Yeah, I had it with a bunch of stuff.
My boards were really old, and they weren't very stable. What I ended up
doing was uninstalling and reinstalling a few times, and it eventually
accepted them. One weird thing that happened was that every ti
me I would
boot up, measurements and automation would add another identical device
(so instead of having 2 devices, I'd be told I had 4, 2 of which were
configured, and 2 were not).
Sorry I'm not of much help. But, try uninstalling and reinstalling them
and see what you get. You might also try to use a few different
addresses. I had the problem again when I upgraded my computer, and it
would not take the old addresses at all. Luckily, this time the default
addresses were not already assigned.
Harry
(3,008 Views)
Same problem, no solutions
(3,008 Views)
I am witnessing a similar problem, after upgrading to MAX 2.0.3.17. It was working satisfactory with previous version MAX (NI-DAQ 6.7).
(3,008 Views)
