PC audio input and output
I face a problem in Labview when I generate the audio signal through the audio out port in the PC.
According to my application I have to generate the audio signal through audio out and feed it back to the PC audio input port after amplification using the external circuitry .
The problem I face here is whenever I generate the signal in the out port the same signal is read  through audio input port without any physical connection.
Can someone help me out.Pls find the attached VI image.
Sandeep
(4,999 Views)
Please post your VI not some large picture that take  ages to download....Smiley Indifferent Also check in your sound card setting that your input source is set to "what U hear" You must also aware of that it is no synchronization between the sound input and output. But I do think that matter for your setup.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,987 Views)
Hi , Can you pls tell me how to check the sound card seetings.
(4,981 Views)
Sssmk! Please understand that we can not debug a pictureSmiley Sad. We need the actual Labview code. And for the sound card setting you will find this in the control panel.
(4,976 Views)
Hi ,
I am sorry..Here is the VI .
(4,972 Views)
The VI you posted can not work. You can use my VI as start. It should work
(4,919 Views)
Thanks for your response.
I have connected Audio out port to audio in port with audio cable but i can not see the out put signal at the audio in.
(4,893 Views)
