PC parallel port access with XP
I recently got In Port and Out Port working on XP.
I searched the ni site for AccessHW. The CVI Run Time Engine has to be
version 5.510 or earlier. I checked the version number of one file, i.e.
cvirte.dll to verify.
I directed the installer to install accesshw to the directory where the new
In Port and Out Port and the rest of the new parallel port .vis were going
to be, i.e. Labview\Labview 6\vi.lib\platform.
I downloaded parallel.zip from ni.com and moved the parallelnt.llb file to
this same directory. Parallelnt.llb has a number of parallel port vis, not
just replacements for In Port and Out Port. I replaced the In Port.vi and
Out Port.vis in the diagrams I was trying to make work with the new .vis.
So, on this XP machine, with
a monitor program, parmon.exe, running to
display the bits on the parallel port, Labview can be seen to be using the
new parallel port .vis, and, bits on the port are changing.
Message 1 of 1
(3,145 Views)
