PCA analysis cant connect matrix to sort columns
I am having a problem trying to connect an 2X2 matrix to the column sort function. I was given a code snipet on this forum which works brilliantly on its own the only problem is when I try to connect it I get a series of errors. I have attached the code so anyone can see if anyone could please tell me what is going on. I am trying to connect the eigenvector matrix to the transpose matrix function just beside it but as soon as I do this I get the errors.
Any help is greatly appreciated.
Regards
Nick
(2,443 Views)
Hi Nick,
The reason you cannot connect your sort function to the eigenvectors is because of a mismatch in data types.  The input is expecting a real matrix but your eigenvectors are complex.  There is a vi to build a real matrix from the eigenvalues which you could the input into your sort function but I don't believe this is what you’re looking for.
Kyle
Regional Account Manager
NI
(2,423 Views)
