PCAN Driver Reading
Hello guys,
I have an issue reading with Peak Systems CAN
Im using this driver: https://lavag.org/topic/15784-cr-pcan-driver_lv2009/
I want to send manual and auto commands via RS485 and observe the CAN msg
Everything is fine with sending Values, but when I read with PCAN I got some issues.
When I send different (sending Manual) values I expect changes on 5 and 6 byte, but there is only change at 4th byte.
When I run the program it changes the values i want, but only a single time.
I think I got an issue using the driver.
Any suggestions?
My code is attached as a zip.
Message 1 of 1
(1,785 Views)
