PCAN-USB adapter with NI-CAN
@xaheer wrote:
Hey can you share how you used it for peak system hardware. I am facing problem in sending payload.
You didn't say what you tried, and you didn't say what is the problem.  I've never used PCan hardware but the drivers on LAVA look fine.
Message 11 of 15
(2,925 Views)
i mean to send physical signal into raw signal i am facing problem of unable to convert them into raw signal, Payload is there any way like in NI/xnet they are done automatically.
Message 12 of 15
(2,923 Views)
I have a toolkit here with some demos and example DBCs.
https://forums.ni.com/t5/Example-Code/CAN-Frame-Signal-Conversion/ta-p/3534000
Look at the example which takes in a DBC path.  It then takes the signal names as strings, and their values, and returns the raw frames that can be written.
Message 13 of 15
(2,916 Views)
Hi Hooovah,
I'm looking for LabVIEW to send CAN Messages to PCAN-USB adapter as interface.
Found this thread, and also went to CAN Frame Signal Conversion - Discussion Forums - National Instruments which you published.
I tried with zip files but seeing VIs are broken.
I'm using
LV 2017
XNET Latest version.
Looking for your support and guide here.
Best Regards,
Sri_F4
Message 14 of 15
(410 Views)
Did you install the dependent packages that were listed? What was broken?
Message 15 of 15
(391 Views)
