PCI 1711 AND ENCODER
With PCI 1711 Daq card, I want to get the data from 360 pulse encoder via labview so that it reads an analog data for each encoder pulse, is this possible?
(1,200 Views)
Hi sedatsen,
I guess you are asking about this Advantech product: you should ask Advantech for their hardware!
According to the manual that DAQ device allows external trigger signals to trigger AD conversion…
(1,186 Views)
hi, first of all thank you,
I talked to Advantech. Daq card supports encoder, but I don't know how to do it in labview.
Best regards.
(1,142 Views)
Hi sedatsen,
Use the driver provided by Advantech for their hardware to initialize and configure your device as needed.
(I guess/hope Advantech also provides manuals and example VIs like NI does for its DAQmx driver/hardware…)
(1,129 Views)
