PCI 5640 IFRIO
HI,
     I am trying to output a sine wave(LABVIEW software generated) to DAC port, to see the output in the oscilloscope. But i can never see the waveform.
My doubt is should i sample the sine and send it in digitised form to DAC only then will i be able to see the sine wave or is the PCI5460 IFRIO fpga borad capable of showing the analog signal fed to DAC output port????
(4,748 Views)
Hello IFRIO,
Please post all questions about IFRIO on the discussion forum for that product.  I was able to locate a post that is very similar to yours here.  Please make any new posts at this location or a new post at the IFRIO forum.
Thank you,
Brian P.
Application Engineer
(4,708 Views)
HELLO,
This is Aman , I am very much new for LABVIEW operation,I am working on a LABVIEW project with PCI_5640 R card. My project needs all Digital Modulation (FSK<BPSK<GMSK<QPSK..etc) at 21.4 MHz Frequency, as i told i m new for labview FPGA so i  am not able to understand how to impliment all this on Labview FPGA, Before this i finished all Modulation on Simple Labview but now  i m getting problem to finished these modulation in FPGA. Please help me out to solve my problem as soon as possible bcoz my project can't be proceed without these modulations...
thanks..
Aman Sanghi..
(4,421 Views)
Hello Aman,
Here is the link to the IF-RIO forums in case you have not found it.
Good luck,
Gerardo O.
RF SW Engineering R&D
(4,380 Views)
