PCI 6229 : connector 0 and 1 with SCB-68 and CB-68LP
I am using Software Details: LabVIEW version 7.1, NI Hardware : Multifunction DAQ device PCI-6229, Driver Version : 7.3, Operating System: Windows XP and I have one SCB-68(connector 0) and one CB-68LP (connector 1) . The problem is I don't understand how the DAQ assistant knows that I have 2 different type ? : because in the device properties + accessory : we can choose only one (so we can choose SCB-68 and CB-68LP at the same time)?. Is it a probleme ?
P.
(2,624 Views)
Refer to the recent thread
http://forums.ni.com/ni/board/message?board.id=250&message.id=10394
Connector 0 analog channels are ai0:15
Connector 1 analog channels are ai16:32
same idea applied for the AO / DIO's and all other pins
ao0:1====Connector 0
ao2:3====Connector 1
as long as the right syntax is used, there should not be a problem
(2,617 Views)
