PCI-6229 generate square waveform have no phase
I use square waveform generate 2 waves,they have 120 phase,but when i through PCI-6229 to generate them ,they have no phase in oscilloscope,i use  DAQ -Assistant only set configuration.
(870 Views)
Hi TC,
Then you made something wrong!
  • Using the DAQAssistent is sometimes considered "wrong".
  • Attaching no source code is most often considered "wrong"…
(827 Views)
