PCI-6533(PCI-DIO-32 HS)
           I have attached the VI here which is for Acquiring high speed continous data for PXI-6534. It is working fine with 6534 as it has got onboard memory and U can see how i have used in the program for integration time but now i am using PCI-6533 instead of 6534 with the same program i am facing some problem here and it doesnt has any onboard memory i am getting an error-10843 So i modified my program little but still i am getting an other error-10010. Here in both the programs i want to acquire high speed pattern of digital data within the specified ON time and the Integration (OFF) time and transfer the acquired data to the memory. But exactly i am getting the error at the first while loop. I have attached both the VI's Pls could any one help me soon. What i have to change in the new program.
Thanks in advance
(2,849 Views)
Hi AutoTEC,
Error -10010 can occur if you attempt to start the output before writing the digital values. Because it is a buffered output, it is important to remember to write the values to the memory before starting the generation.
Error -10010 is also addressed in KB 45NAIHBE: Error -10010 with DAQCard-653x When Writing to Buffered Digital Output (link) and also in KB 133F5FBS: Why Do I Get Error -10010 with My DIO-32HS Board?
If you have any more questions, please post back with a version of your code that is reduced to what is required to throw the error. Doing this will help resolve problem much sooner.
Ryan D.
District Sales Manager for Boston & Northern New England
(2,817 Views)
