PCI-6601: change HIGH_TIME while task running?
Hello, I'm using PCI-6601 for pulse output. My question is simple. Can I change the HIGH_TIME value while program is running?
When I see in Labview Help, it says that depends on device used:
I don't know what category PCI-6601 belongs to. Any help would be greatly appreciated.
(2,789 Views)
This should be a TIO device, are you using daqMx drivers?  You should be able to change the duty cycle on the fly with a task property write.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,781 Views)
