I have a PCI 6601 DIO/Counter and a CB-68LP connector board. I am using this to control two 110V motors which currently are controlled by 2 limit switches; one for a shutter motor and the other one for a azumith motor. Each limt switch allows each motor to turn in Forward and reverse directions.
(Please see the attached wiring diagram of the limit switches).
1. Shutter Motor:
For forward direction, lines 3,8,+V,are connected and 5,2,4 are connected.
for reverse Direction, lines 3,+V,2 are connected and 8,5,1 are connected.
2. Azimuth motor
For forward direction, lines 2,1,3 are connected and 4,5,6 are connected.
For Reverse direction, lines 1,2,4 are connected and 3,5,6 are connected
Could you please tell me what woul
d be the easiest way o program this in Labview? what will my block diagram look like? Any help will be appreciated since i am a very beginner in labview.
