PCI-6713 different updaterate with new driverversion
Hello!
I was just wondering if the maximum updaterate for PCI-6713 / 6733 cards has changed due to new driver version.
The old manual (322080E-01 / June 2002 Edition DAQ 671x & 673x Usermanual) said that the update rate
with 1 - 5 channels is max 1MS/s and for up to 8 channels it is max. 769kS/s (p60 chapter A-2)
The new manual (370735E-01 / June 2007) said nothing about any derating of updaterate with use of 8 channels.
May I therefore expect all 8 channels be able to operate with 1MS/s ?
BR Joerg
(2,800 Views)
Hello J_Edegger,
Thank you for your post on our webforum. The specifications from the NI 6713 and NI 6733 are documented in a seperate document. Please find the following links;
NI 6713; https://www.ni.com/docs/en-US/bundle/ni-6711-6713-specs/resource/371011c.pdf
NI 6733; https://www.ni.com/docs/en-US/bundle/ni-6731-6733-specs/resource/371232b.pdf
If you are using less then five channels a FIFO update rate from 1 MS/s is possible. There are some specifications when using PC memory; this is depending on your PC hardware configuration.
Martijn
NI Netherlands
Martijn S
NI Netherlands
(2,792 Views)
Hello Martijn!
Thank you very much for your answer!
Its now clear to me Smiley Very Happy
BR Joerg
(2,786 Views)
