03-10-2012 04:21 PM
I am attemoting to set up an ETS on an Intel DH67CL motherboard. I am using the PCI-8232 Ethernet card that comes with the ETS bundle. The motherboard has 3 PCI slots and when I place the card in (slot numbering :
Slot 4: On boot, does not make it through POST and gives the beep codes for not being able to find video.
Slot 3: Same as Above
Slot 2: Gets through boot, starts the LV USB Utility. When I run "7. Evaluate System". I get a error:
03-12-2012 09:22 AM
03-12-2012 10:30 AM
Hi, I found these KBs related to your hardware. Try to follow these steps to enumerate your device on your PC.
Link1: http://digital.ni.com/public.nsf/allkb/7AEC81D93341F70686256AD800726906?OpenDocument
Link2: http://digital.ni.com/public.nsf/allkb/5827EA5251039A0A86257513007A9B22?OpenDocument
03-12-2012 11:37 AM
03-12-2012 04:41 PM
I'm not familiar with ETS, it is like a real time os or a bootloader?
Best Regards,
Miguel Fonseca
03-12-2012 09:42 PM
It is the real-time stand-alone. I am essentially installing per:
http://www.ni.com/pdf/manuals/371857f.pdf
I am configuring using a USB and then formating and installing the RTOS.
03-15-2012 09:56 AM
First I'd like to ask you, which processor you are working with?
Then, I found this information related with your board and the ETS compatibility:
Mother Board: http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-dh67cl.html
Requirements to run ETS: http://digital.ni.com/public.nsf/allkb/D83956770EF7D69B86257405005D2675?OpenDocument
Does your board completes these requirements?
Best Regards,
Miguel Fonseca
03-15-2012 11:39 AM
03-15-2012 11:42 AM
03-16-2012 11:58 AM
Hi bradth,
Thank you for the details of your system. To begin, first let's run a compatibility test on your system by using the utility found in this KB Article (http://digital.ni.com/public.nsf/allkb/9209361E17708D548625744A007FF353). Please post a screenshot of the results so we can take a look at the full configuration of your sytem. Let me know if you have any questions. Thanks!
