PCI-8430/8 (RS-232 INTERFACE)
Hi guys. Here's the problem, i have already installed PCI-8430/8 device on my system unit. but .... (see the image "PCI2") that happen. What was wrong? did i miss something??
then i search for solution.. I got an answer that i need to install NI-SERIAL my compatible version is 15.0 (see image "PCI1")  then i downloaded it and install after. but still did not fix my problem.
Any related answer to my problem is much appreciated.
(2,971 Views)
Accepted by topic author 1der-er
Try delete device and reboot PC. Usually you need install drivers before plugging device
(2,913 Views)
THANK YOU SIR. YOUR ADVISE IS A GREAT HELP, IT WORKS!! APPRECIATED MUCH ❤️
(2,903 Views)
