07-15-2008 09:39 AM
07-15-2008 01:16 PM
07-15-2008 02:52 PM
07-15-2008 03:48 PM
07-15-2008 04:55 PM - edited 07-15-2008 04:56 PM
DIO Port Write is not the same thing as DIO Write and DIO Port Read is not the same thing as DIO Read. They are not interchangeable but all of these functions have always been part of the driver. None are 'newer' than any others. I have traditional DAQ installed and have no problem placing any of these old functions on the block diagram. What is the version of traditional DAQ that you have installed and do you have the traditional DAQ driver selected in MAX? You should be able to use the old driver but as mentioned, at some time, you should consider switching to DAQmx.
07-16-2008 07:23 AM
07-16-2008 07:29 AM
07-16-2008 08:38 AM
I don't remember the exact procedure but I think that the device would appear under both traditional DAQ and DAQmx. You needed to right click and select Make Active or the selection was in the properties.
There version is shown in MAX. Expand the software listing and select Traditional DAQ. Information will be displayed in the window on the right side.
All of the traditional DAQ funcitons call into the same dll so I don't know why placing one specific one on the block diagram would cause a problem and others not. What's your OS? It's not Vista is it? Assuming you have the latest version of traditional DAQ (7.4.4) you could try doing a repair or reinstall.
