PCI Device via Call Library Function
Hello NI developers! Searched through the forums and nothing found for this topic.
I have a program that reads data from PCI board memory. Stuck with using CIN's and decided accomplish this task with Call Library Function Node.
I use linux Ubuntu and program C code, LabView 7.1 i specify -lpci library for compiling my code. and use header file included.
1) How to pass to Call library function node - parameter which is defined in "pci.h" as a structure with pointers?
2) Do I need to write wrapper for it ? If so is there well manuals?
3) Can I compile my entire program (which uses functions defined in pci.h and in library libpci.so) as a shared library .so and call functions directly from my library? or I should call those functions only from libpci.so separetely?
Thank you in advance! Message Edited by bI on 03-22-2008 08:14 PM Message Edited by bI on 03-22-2008 08:15 PM
Message Edited by bI on 03-22-2008 08:16 PM
(2,791 Views)
P.S: I use mmap( .... ) function to return a pointer to memory where data is.
(2,743 Views)
