PCI-GPIB Card problem with window 98
I have window 98 and when I install GPIP card, my PC can't boost any more. Please tell me how to solve that problem.
Thank!!!
(3,041 Views)
Take a look at the following link and see if it helps you out:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/8d187ddf25eab5ee862569580058204c?OpenDocument
Brian
(3,041 Views)
Could be a conflict with the video card (especially if it's ATI, which is using tones of resources) because the system allocates resources automatically for the new inserted PCI-GPIB and not always is doing it properly.
(3,041 Views)
The answer with the link to a Knowledge Base Online is very good, updating the BIOS of the computer is the best shot, but also you may try to change the PCI-GPIB board to a different PCI slot in your computer this may help. Do you have other PCI boards like ethernet boards? Try switching them or take out momentaneously the ethernet board and install the GPIB board to figure out if the conflict resides on using this two boards together.
If you have more questions about this issue you may contact us also by phone so we can give you more extensive help, refer to this link to get directions on how to reach us.
http://sine.ni.com/apps/we/niae_asc.main
Good Luck!
Nestor Sanchez
Applications Engineering
Nestor
(3,041 Views)
