PCI device driver development in CVI for RT OS
I'm writing a driver for a PXI card that uses the 9030 bridge chip for PCI
access. This device needs to be used with the national Instruments( NI )
Labview real time OS( LV RT ) in a PXI instrument rack. I have the WIN32
API driver code for the card and need to redevelop it for LV RT. I need
assistance in the following area: How do the VISA calls to access
Configration space and BAR0 -BAR5 space map to PLX IOPsace0-4  and the PLX
registers on the 9030 chip. In other words; how do I translate a call in
the current driver, lets' say for example a write to an offset into
IOPspace1, to a call that writes to an offset into a particular BAR0-5
space ? Or how I translate a call in the current driver, lets' say for
example a write to an offset into a PLX register( PlxRegisterWrite(...) )
into an offset into a particular BAR0-5 space. I can state the following
facts: I can successfully  read the PCI configuration space registers using
the VISA API ; the VISA API tells me that BAR1 is configured for IO access
with a space of 0x80 bytes; the VISA API tells me that BAR2 and BAR3 are
configured for memory access with a space of 0x1000 bytes. Does this mean
BAR1 translates to PLX register data, and that BAR2 and BAR3 are equivilent
to IOPspace0 and IOPspace01? What's the difference between a BAR space
being configured for memory access, and a BAR space being configured forIO
access?
  Having these cards work in the LV RT OS will be a huge selling point for
NI PXI.
Thanks for any assistance you can provide.
Regards- Dean
(3,047 Views)
Dean,
I am going to link this post back to your original post in the CVI forum for completeness sake:
http://forums.ni.com/ni/board/message?board.id=180&message.id=27092#M27092
Simon H
(2,997 Views)
