PCI6225 port2
Can I use port0,port1,port2 simultaneously, I use PCI6225,when I use DAQmx assistant, select all port, it displays the following error.
Error -201062 occurred at DAQ Assistant
Possible Reason(s):
Selected lines do not support buffered operations.
Ensure only lines that support buffered operations are being used in the task. If using change detection, the task must be changed to non-buffered hardware timed single point to support these lines.
Thanks a lot
maincool
Message 1 of 1
(2,377 Views)
