PCIe-6353 LIN communication
Hi all,
I'm a beginner in LIN communication, so i need some help with it,
Can i communicate on lin with PCIe-6353? ( https://www.ni.com/en-us/shop/model/pcie-6353.html )
If yes, can i get some guide how to create labview code for it?
(i know its possible in other languages)
Thanks!
(3,905 Views)
Use the below link for a start which contains manuals, drivers, knowledge base and few discussions.
http://sine.ni.com/psp/app/doc/p/id/psp-893/lang/en
Let us know if you stuck up at any particular point.
(3,869 Views)
Not sure if you can, but you definitely shouldn't.  Use the appropriate hardware for what you need.  If you want to talk LIN, use a LIN card.  The XNet API can handle importing databases, performing acknolegement, setting up schedules, CRCs, handshaking, scaling, message queuing, etc.  The card you linked to has DIO, turn a line on, turn a line off.  Is this intended on being in a Windows PC?  Then you'll be stuck with software timing trying to handshake.
That being said I have used a digital input card to verify a LIN transceiver was installed properly.  The LIN device was a master and would send out data and a schedule on its own.  So all I needed to do was to look at the digital inputs and see that they toggled to know it was installed right.  Without a real LIN card I couldn't tell you what the data was, or if it was working.
(3,843 Views)
