03-16-2010 06:53 AM
I am loking to use PCIe 6537 and I am seeing if anyone has used LabView to interface to it?
Is there any sample code around?
Simon
03-16-2010 08:08 AM
Hi Simon,
you will find some Examples in the Example Finder. Search for 6537. Attached you'll find the results.
Mike
03-16-2010
03:41 PM
- last edited on
07-17-2026
08:32 AM
by
Content Cleaner
Hello Simon,
As long as you have NI-DAQmx installed you will have the examples that Mike mentioned in the NI Example Finder. Also, you can do a NI search for the 653x boards and narrow the search down to see examples that have been created by Applications Engineers here at NI, as well as other users. This should be a great start, and please let us know if there is an application in particular that you are looking for and cannot find.
07:07 AM
- last edited on
07-17-2026
08:32 AM
by
Content Cleaner
If you are new to DAQ programming, check out the following useful tutorial.
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
