PCIe6535 not recognised on real-time linux x64 5.10.115-rt67
I need to use a PCie 6535 card on a NI-PXIe-8840Quad-Core-031EA898, running NI Linux Real-Time x64 5.10.115-rt67.
The card does not appear on NI MAX, even though others do work correctly on that system. I am currently using Labview version 2022 Q3 on the local computer, and it has been working well with the system except for that card.
I tried relocating that ard to another slot, but this did not make a change. I also tried to look for drivers but I can only find the windows compatible ones (here).
Have I missed something?
(1,115 Views)
Is that a typo? How can you use a PCIe module on a PXIe chassis?
Anyway, 6535 is not supported on Linux RT.
NI Hardware and Software Operating System Compatibility
https://tmesystems.net/
(1,092 Views)
It was indeed a typo, that is a PXIe card.
Thanks for the answer, I did not know that link. It will prove useful.
(1,084 Views)
