02-01-2007 11:16 AM
02-02-2007
10:54 AM
- last edited on
08-10-2026
10:53 AM
by
Content Cleaner
Hi Andrej,
Thank you for posting to the NI forums. This is the expected default behavior for your device, and in general, all of our PCMCIA devices. Unlike our PCI devices, PCMCIA devices do not support DMA – they are interrupt driven. The default interrupt to trigger the onboard data fetch into RAM is setup to occur when the onboard memory is more than half full. You can change this setting to fetch the data when the onboard memory is simply “not empty”.
I hope this helps! Please post back if you have further questions.
Ed W.
